Lube Winch Cable?
Old Jul 11, 2009 | 03:19 AM
geoffcwilson's Avatar
Default Lube Winch Cable?
Lube it ir not?
Old Jul 11, 2009 | 06:21 AM
Biggy's Avatar
Its a good idea once in awhile. For sure if you submerge the winch
Old Jul 11, 2009 | 06:26 AM
09rubicon's Avatar
I lube every few months.
racer83l's Avatar
every month, I spool out the cable, spray the entire length with WD-40, and then spool it back in under tension (I hook it to a 30yd dumpster we have in our yard, with the JK in 4-lo and reverse and then winch it in)
No rust on it yet (its almost 1 year old and I live in an area where they salt the roads in winter time)
Old Jul 11, 2009 | 08:38 AM
Is WD-40 ok, then? I was thinking more of a dry lube.
Old Jul 11, 2009 | 08:41 AM
racer83l's Avatar
I use wd-40 because it is meant to prevent rust. thats really all I am trying to do. once the cable gets frayed/cut Im going to go synthetic.
Old Jul 11, 2009 | 10:34 AM
NTXJK's Avatar
I use it all the time no rust
Old Jul 11, 2009 | 10:35 AM
scottrock's Avatar
ditto on the WD40.
Old Jul 11, 2009 | 10:46 AM
RedneckJeep's Avatar
WD 40 is great for this because it displaces water....as the initials imply. "WD" stands for "water displacement".
Old Jul 11, 2009 | 10:49 AM
voodoojk's Avatar
and the 40th formula they tested anbd approved
