Lunchbox locker in a open 2010 d44(rear),need help?
Old Jan 21, 2011 | 05:16 AM
shotwell's Avatar
Default Lunchbox locker in a open 2010 d44(rear),need help?
I have a 09 Wrangler with a LSD 3.73 gears.Anyway I recently picked up a 2010 open carrier out of a 2010 JK with 3.73 gears.What lunchbox locker will fit.I was also told the 2010 carrier was alittle wider internally,any truth to that?Would like to stay Lockright as that what is in front,but any of them i`d consider.
Old Jan 21, 2011 | 05:52 AM
wayoflife's Avatar
JK-Forum Founder
don't see any reason why there wouldn't be a lockright for the rear but if not, i'm pretty sure that aussie locker makes one too and they're pretty much the same thing.
Old Jan 21, 2011 | 01:28 PM
shotwell's Avatar
I think 2410 is the lockright,and sl d44-30 is the sparton,anybdy know what aussie part number?
Old Jan 21, 2011 | 02:33 PM
mkjeep's Avatar
I have a lockright in front, put a Detroit in the rear. f you want an auto locker for the rear, why not put a Detroit?
Old Jan 21, 2011 | 07:06 PM
shotwell's Avatar
cause I`m cheap........lol
Old Jan 21, 2011 | 07:12 PM
nthinuf's Avatar
Lunchboxes may not be the best option for the rear axle. More of a temporary solution rather than a permanent one, since they will wear out. They'll work better up front where they are only in use part-time.
Old Jan 21, 2011 | 08:10 PM
shotwell's Avatar
Before this turns into"what I should do" .Lunch box lockers are not for everybody,I understand.
Old Jan 22, 2011 | 02:25 AM
Rhino64's Avatar
I had a lock-right in my TJ ran it for thousands of miles never any problems.
Old Jan 22, 2011 | 03:39 AM
bubba2u's Avatar
i dont think anyone makes a lunchbox locker for the jk d44. i put an aussie in the front
d30 and will be putting a detroit locker in the rear when i have the cash.
Old Jan 22, 2011 | 03:41 AM
Jeter's Avatar
PTX2410-LR should be the part number you need for a rear D44 in the lockright. Check with your parts supplier to make sure but this is for a 30 spline axle.
