M/T Toyos Only
Alright. I did a google search and found all the discussion you are talking about. My bad. I wouldn't think a tire manufacturer would put a tire out that would do that. Seems there is a problem. Guess you could run Toyos on one side and Nitto on the other LOL.
First I don't, and haven't run Toyo's.
I want to comment on the pulling issue. I had Nitto Trail Grapplers, had a SLIGHT pull to the left. Thought maybe alignment was off just a touch....
Got a set of Goodyear MtrK's. NOTHING else was done, had a slight pull to the right.....Maybe it's all in my head.....
Thanks for all of the replies guys/gals. I've tweaked the uppers and lowers, had it aligned when the tires were first put on about 15K ago. I do a 5 tire rotation every 5K. Perhaps I should try to toe in on the right and toe neutral to slightly out on the left and see what happens. So far the only thing that made a noticeable difference was lowering the tire pressure on the left tires and running them slightly high on the right, but that was just an experiment. Seemed to quell the pull to the right.
