Major Mods this weekend.... Couldn't be happier!
Old Jan 3, 2012 | 04:32 AM
Ringer's Avatar
Default Major Mods this weekend.... Couldn't be happier!
Finally got my brand new Rubicon front and rear crate axles installed this weekend. The front got sleeved, gusseted, LCA skids, and I have BTF diff covers for both front and rear. The diff covers will go on when I change the gear oil after a 500 mile break in. I also installed RK front and rear LCA's. I had the 2.5" stock mod lift, and installed these along with braided stainless brake lines to make it basically the max travel kit. Holy crap what a difference! I have a 2008 2dr X with 3.21 gears. Moving to 4.10's and having the castor set right makes this thing drive like a dream! No more death wobble!!! I wired the lockers to a custom switch panel that I made complete with the LED indicator lights to show engagement. I also finished welding up my rear bumper with tire carrier that will be linked to the rear gate...
Expensive, but great weekend... Only downside is that when I put the Jeep up on the lift I realized that I gained engough travel that I need a front driveshaft, as the boot is rubbing the exhaust.
If anyone in NE Ohio is looking for a set of complete axles, let me know.
Old Jan 3, 2012 | 05:41 AM
zombie4x4's Avatar
so with the new axles did you rig up electronic lockers? or what type of lockers are you running?
Old Jan 3, 2012 | 05:48 AM
Ringer's Avatar
I am running the factory Rubicon electric lockers. They are wired independently to a relayed switch from the locker, and an indicator light to the sensor. I am running all sealed Deutch connectors, and added a Painless fuse block for the accessories. Each locker is on it's own 10 amp circuit. Works awesome... I will try to get pics of the switches.
