Manual trans
Old Jul 26, 2011 | 03:03 AM
dadof2girls's Avatar
Default Manual trans
I hope this is a simple fix! When I press and let off of the clutch I get a clicking. I was told that there is a push rod on the driver side of the trans that has a black cover on it, that if I remove the cover I can grease it and get rid of the clicking. Anyone have this same issue??
Old Jul 26, 2011 | 05:08 AM
CrazyShadow's Avatar
When pressing/depressing my clutch I heard squeaking too.
Also when clutch is fully depress on neutral and engine at idle, I can hear something loose vibrating but as soon as I barely touch the clutch the sound disapear.
Ive hear many JKer on the forum talking about throwout clutch bearing.
28500 km here, I will have it check by stealership at my 30k maintenance
You can also look in this similar thread for more informations: https://www.jk-forum.com/forums/show...clutch+bearing
Old Jul 26, 2011 | 05:27 AM
vandegrift's Avatar
Yours definitely sounds like the throwout bearing, and they it should be covered under warranty. I had to do the same thing myself. But for the first post, if you try it, let me know. I am getting the same click and it is not the throwout bearing.
Old Jul 26, 2011 | 11:33 AM
Cleaning and regreasing the slave cylinder seemed to quiet it down some. I may have to flush the clutch also.
