max lift, 2dr Rubi
Old Oct 11, 2008 | 04:01 PM
schnee's Avatar
Originally Posted by jkkat
and gets a 1000 on an RTI ramp.
Forgive me, but what does this mean? And the TF 2.5" is the lift I was looking at. Do you rub at extremes or is all good?
Old Oct 11, 2008 | 10:06 PM
schnee's Avatar
Nevermind, live.com is my friend
http://www.offroaders.com/info/tech-corner/rti.htm
Last edited by Robar; Oct 12, 2008 at 02:22 PM. Reason: PLEASE DO NOT POST DIRECT NON SPONSOR LINKS
Old Oct 12, 2008 | 04:17 AM
jkkat's Avatar
I do rub in several places, only because of the fact that i ONLY have the stock bump stops in and left out the extentsions.
rub front; sway bar, frame, little bracket that holds fender flair up, fender flair
Rub rear; pinch seams even after hammered over, rock rails
Old Oct 12, 2008 | 09:35 AM
style_front's Avatar
I also vote 37's
Old Oct 12, 2008 | 09:45 AM
08RUBIJK's Avatar
If you just want a DD and want don't want to spend a bunch of $$ on a lift and tires, just put a 1" body lift on it with a set of 3/4" spacers on the front. You can then run 33" tires. If you keep your Jeep for awhile and end up wheeling it more, you can then add a suspension lift and bigger tires.
Don't feel pressured to put bigger tires on just because everyone else is. 35" tires will suck a bunch of the life out of the 3.8L and then you will end up spending money for gears.
Old Oct 12, 2008 | 02:16 PM
schnee's Avatar
Most definately. I'm pretty sure I'll be content with 33's for a while so I'm concentrating on that. I like a 2.5" coil lift will support that, plus give me some good places in the future to move to. I think with a 1" - 1.5" body lift on top of that, 35's won't be an issue if they had any issue with the 2.5" coil lift.
I don't think I'll need to regear with 33's either and I'm pretty sure I'd want to with 35's. Thanks all!
Old Oct 12, 2008 | 07:26 PM
hyatt147's Avatar
I run a 4" with 35's and the only mods ive done to the driveline is adjust the pinion angle by adding rear upper arms. I drive it daily and have no rubbing and no driveline vibe at all. 11k miles on the lift so far.
