max tire size on a front 44
Old Oct 19, 2008 | 07:38 PM
xjthextremejeep's Avatar
Default max tire size on a front 44
what have you guys found to be the max tire size without alot of breakage on the stock rubicon 44s?
Old Oct 19, 2008 | 08:54 PM
wayoflife's Avatar
JK-Forum Founder
i am running 37's on my 44's and with the addition of chromo shafts, they are holding up just fine. however, i personally wouldn't go any bigger than that.
Old Oct 20, 2008 | 07:51 AM
VictorS's Avatar
Ditto here. Many people will say that 35" is the max, however, I have wheeled extensively with 37" and the 44 have held up so far. I would recomend getting the EVO "C" reinforcement brackets and chromoly shafts. Use a light foot on the accelerator when wheeling rough stuff.
Old Oct 20, 2008 | 08:55 PM
tburk49760's Avatar
really depends on how tough you are on it. I have seen knuckleheads break Dana 60 front axles with 33inch tires... I also have run 36" tires on a model 30 axle for many years of mostly moderate to wild offroading... The general consensus seems to be that 35" is the safe limit with no extreme wheelin'
