Max tire size with modified Dana 44's
Old Aug 17, 2011 | 09:26 AM
CMEFLX's Avatar
Default Max tire size with modified Dana 44's
Just seeing what everyone’s opinion is on the max tire size/width that a modified dana 44 (front & rear) could handle with light to medium wheeling and daily driving duties. Here’s the set up I’m plan on doing. The front axle will have Evo magnum sleeves, C-gussets, LCA skids, Currie Enterprise track bar bracket, ******* Suspen ball joints and re-geared to 4.88. the rear axle will just get re-geared and the Currie enterprise track bar bracket. I could possibly re-weld the spring mounts to prevent spring bowing and add 1.5 wheel spacers. Any input will be greatly appreciated.
Old Aug 17, 2011 | 11:51 AM
scotty6336's Avatar
couple variables still. Auto or Manual most importantly (for gear reference). But on a modified 44 I'd be ok with running...mabe...a small 40x13.5, ie not a swamper or pitbull, but mabe a KM2. But you'd still run a risk. The other main factor is how hard you beat on it. And 4.88's wouldnt cut it. But thats max, and just my opinion. Generally speaking, a six speed, front/rear 44's and 4.88's with 37x12.5's should be a good combo.
Old Aug 17, 2011 | 01:41 PM
CMEFLX's Avatar
oops, i guess those would be a factors. i have a 4dr rubi manual. and due to my current location. i dont get the opportunity to go wheeling that often. So I guess you could say that I do light wheeling, but I don’t want to limit myself to that. I pretty light footed so breaking axles shafts shouldn’t be a problem. 37’s are looking be the choice, but 38’s might be a possibly as well.
Old Aug 17, 2011 | 02:16 PM
nthinuf's Avatar
It's another of those questions that no one can answer. Some are fine running 37's on a d30, others are bending or shattering factory 30's and 44's running stock tires. But, gusseted and sleeved, and with your stated use, you 'should' be fine with 37's/38's. Tire placement and a light foot with go a long way... unless you have a front axle with the suspect metallurgy...
