Maximum ft. of Synthetic on a Warn PP?
Thinking I will replace my 80' of 3/8" cable on my new Powerplant HD with Synthetic and have been looking at the Amsteel blue. What is the most 7/16' I can spool and what is the max 3/8" I can spool I would like to be somewhere between 80-100'? I have not used it so the fairlead is spotless will I still need to replace it with one of the hawse models?
Thanks
Thanks
Dave at Northridge 4x4 will know.
http://northridge4x4.com/jk.php
Also, Woods will know.
http://www.jeepswag.com/
More likely the Warn PowerPlant guys own an HP model, not the HD. The HP model is the right size for the JK, and allows a longer line length. So, our experience would not apply to your situation.
BTW: Since your roller fairlead is "spotless", you should be fine using it. The Hawse fairlead does have the advantage of smaller size and lighter weight.
I just saw an article on this in a magazine but cannot find it now. I'm pretty sure it was in Petersens 4-wheel drive. With the larger winch you will also likely run cooler. Even better for the synthetic rope.
