Mbrp exhaust noise
Old Jul 26, 2011 | 02:22 PM
Msspenc's Avatar
Default Mbrp exhaust noise
Installed the mbrp at back exhaust on my 2011 2 door and have a clanging sound in the rear whenever I go over any bumps at moderate speed. Checked the clamps and everything is tight and in place. The rubber exhaust hangers look a little stretched. Anyone else experiencing this or know a fix?
Old Jul 26, 2011 | 05:45 PM
Hexavalent's Avatar
I have the MBRP exhaust as well and when i installed mine, i also had a lift kit installed that included a rear sway bar drop bracket. The dropped sway bar was very close to hitting the inlet pipe to the muffler and made clanking noises. I just took off the drop bracket and problem solved, maybe your problem is similar?
Old Jul 27, 2011 | 04:17 AM
Msspenc's Avatar
No, it has the stock suspension on it. The noise sounds like the muffler is bouncing up and slamming into the top of the tub
