Metalcloak Thread
Old 06-05-2014, 06:14 AM
  #1381
Invest2m4's Avatar
Originally Posted by snags922
Ya, I will. On a separate note, it was discussed the other day about installing the control arms and track bars while all 4 wheels are on the ground. All control arms except the front uppers are longer than the stock. So how well does that work when you are trying to install longer CAs? I'm missing something here.
Haha, exactly. However works for you, so long as it's safe. I remove two arms at a time (driveshaft connected). Life is far easier with someone helping as it takes some motivation to rotate the axle. Obviously, put coils in after arms. I do track bars after the whole thing is done and I've torqued all the arms.
Old 06-05-2014, 06:22 AM
  #1382
14Sport's Avatar
Originally Posted by Invest2m4
Moving to the front should do it. Definitely if you have a 1310 shaft. Moving to the back is only an option for 4 doors. Haven't heard any issues, but I'd only use the afe system in that case (but it is really expensive). I'm also not convinced that it can't have long term issues with the engine. It's a pretty big change.
That said, Chrysler probably could have located the exhaust rearward, except they can't on 2 doors so they put it in front. Just a guess. I'd assume afe consulted with someone from Chrysler or who used to be there...
Well I just got back from the muffler shop. He hadn't seen any 3.6s yet and the first thing he says is WTF is this...lol...looking at the exhaust loop. So we found the best places to cut (all three on the y pipe) and he said it would be about a $100. However, he warned me very sternly that if he cuts the pipe then Jeep WILL void my warranty. I told him about the afe pipe and he said since it was bolt on they may approve it, but it would have to be pre-approved by Chrysler. I told him I wasn't too worried since jeep would have to prove the exhaust mod caused the failure of the warranted part in the event of a failure. He was very busy and told me to call next week for an appointment.
Old 06-05-2014, 06:25 AM
  #1383
dalearyous's Avatar
are you referring to this? Rancho RS720003 - Rancho Exhaust Pipe Kit for 12-14 Jeep® Wrangler & Wrangler Unlimited JK with 2-5" Lift - Quadratec
if so crap, i might need to send it back.
[QUOTE=Invest2m4;3925153]
Originally Posted by kjeeper10
Great idea moving the exhaust back. Doesn't Rancho also offer a relo pipe.[/QUOTE
Same deal, but worse. It essentially curves the pipe down to clear the driveshaft. Although, if used while off roading, it's a very effective way to remove your exhaust system.
Old 06-05-2014, 06:28 AM
  #1384
snags922's Avatar
I thought I was missing something. I am going to be doing this by myself for the first 4 hours tomorrow so I want to do it the safest way possible. I agree that all 4 wheels on the ground is definitely the safest. I just wish someone would elaborate on how you bolt up the longer CAs with all 4 wheels on the ground. What is the trick that I am missing?
Sorry for all the dumb questions today, I am a computer guy by trade...I am not a mechanic! And I need to get everything straight by tomorrow. I really do appreciate everyone's help.
How did people take on projects like this before there were forums...!
Old 06-05-2014, 06:51 AM
  #1385
14Sport's Avatar
I didn't do it that way. However, I did have to adjust some arms after install and I used a wheel chock in front of the tire and then drove into it a few times to align the ca for the bolt. It actually works. You can also do it with 3 wheels on the ground. Take a look at six minutes into this video. You can see he uses a floor jack under the pumpkin to manipulate the axle to align the holes. That's how I did it. But I had to use a ratchet strap to align the track bar.
Project: MF JK Part 1 | Xtreme 4x4 | PowerBlockTV - Full Episodes
Old 06-05-2014, 07:01 AM
  #1386
Bypass's Avatar
It works fine. They aren't that much longer so it won't affect anything.
The joints are pre greased.
Old 06-05-2014, 07:07 AM
  #1387
Bypass's Avatar
The easiest way to make the front coils slip in is to, remove both sway links, remove the shock, do your extended brake line, remove at least one end of the track bar, remove at least one end of the front lower control at on that side.
This way the axle will droop further than it normally could and you can slip the coil in.
Be sure to drill your hole and test which bumpstop height you want before installing the coil. Install the coil with no bump extension, then slide the pucks through the gaps in the coils and bolt it all together with the axle drooped so you have lots of room to ratchet.
Old 06-05-2014, 07:09 AM
  #1388
snags922's Avatar
FYI - I just talked to MC because I wanted to hear it from them on greasing the joint. He said they really need to take that section that talks about greasing the duroflex joint and assembling the joint out of their instruction. All duroflex joint do come pre-greased.
Old 06-05-2014, 07:30 AM
  #1389
BrigadierJK's Avatar
Anyone have experience with running the Metal Cloak Tie Rod?? I just installed it recently and it gave me a few concerns especially when talking with the Metal Cloak Advisor. I'm running it with the Reid Racing Knuckles and I could barely get the nut on top to tighten it down so it doesn't seem like its on their good. When I called Metal Cloak, the guy seemed to know his stuff but told me that, thats the way its supposed to be and that the Knuckles do NOT need to be Reamed. Apparently Reid Racing and Metal Cloak have collaborated on it. Anyone not ream their Knuckles and how is it working out for you? Also the metal threads are hardened steel which doesn't allow the steel to get crushed whatsoever when its tightened down which leads me to believe that my Tie Rod could wiggle itself out over time. Anyone have an experience with this or hows it working out for you?
Old 06-05-2014, 09:17 AM
  #1390
jnabird333's Avatar
This is true but with 4k miles on my arms they squeak like crazy when hitting speed humps so I will be regreasing mine soon.
Quick Reply: Metalcloak Thread
