Metallic Click After Mods
Old Apr 30, 2014 | 02:37 AM
FDHog's Avatar
Default Metallic Click After Mods
Had a lift/gears/front driveshaft installed.
When up shifting, or if I decelerate/accelerate, I get a light metallic click. Can only hear it with radio off.
Front U joints are all new.
Could it be my new Tru Trac in rear?
Old Apr 30, 2014 | 04:46 AM
OH9JK's Avatar
JK-Forum Ambassador
Check the bolts on the control arms. If the factory hardware was re-used there is a metal tab on the nut that can sometimes come in contact with the arms causing a faint metal on metal click or squeak.
Looks like this....
Old Apr 30, 2014 | 05:29 AM
Dahmer's Avatar
I currently have that problem but it's because the trac bar joint is wore out. So I agree it could be a loose bolt.
Old Apr 30, 2014 | 05:41 AM
FDHog's Avatar
Thanks
Ill check as soon as the friggin monsoon stops
