Mickey Thompson ATZ or ProComp Xtreme AT tire?
Let me ask three questions in one post:
1. Since I am looking specifically at 305/65R17, the Mickey's in that size are N rated for speed. Almost all the other sizes are Q rated. Does it mean I should expect poor balancing with the N speed rated 305/65/R17 Mickey's?
2. Pro Comp's are directional. How do you guys rotate your tires? Or it doesn't really matter which direction they spin?
3. Is ATZ P3 a replacement for ATZ Radial? Somewhere I read that's the case. Does anyone know?
Thank you All for the input. I've just pulled a trigger on ATZ Radial 285/70R17/8. Should get them by the end of next week, hopefully. I like tread pattern a lot, 3-ply sidewall, load range D (E would be a little too much for 2 door JK I think, and based on some reviews/opinions), rated Q for speed. I was considering 305/65R17s too, but those are E load rated and what I didn't like in particular was N rating for speed. I was concerned they may not balance well.
It took some time to research and for facts to settle. ProComp A/T is a fine tire, but I don't like the fact that they are directional which makes rotation somewhat awkward. Plus, they don't offer OWL sidewall which I prefer. I was almost ready to go Toyo Open Country A/T II route, but despite being a great tire it didn't feel right because I was looking for bolder tread blocks/pattern. Getting Toyos felt like a compromise, not to mentioned diminished justification for changing out stock tires.
Thank you again! Hope to get and mount them soon, and post some pics.
Here are some apple-to-apple comparisons. Two of the 5 tires balanced with so little weight folks at the shop were surprised. Remaining 3 took about average amount of weights to balance for an LT tire in this size (285/70R17). No shaking or vibration at highway speed. There is a fairly low humming sound, but you have to purposely try to listen to fully hear it, and I have a soft top, as you can see. I was expecting much worse just by looking at the tire tread blocks. Looking at the very initial wear it seems recommended PSI stated at the door panel (34psi/240kPa on mine) is the pressure to run in these, maybe even lower, will see. I have 36psi right now and it appears edges are not getting quite enough road contact.
