Mileage and Mph difference with bigger tires?
Old Jul 2, 2011 | 04:09 PM
davyjones616's Avatar
Default Mileage and Mph difference with bigger tires?
I recently upgraded my stock 29 inch goodyearHT's to Dean 315/75/16 mud terrain sxts (35s). Im wondering if anyone know the mileage difference on the odometer, mph and mpg... Or how to calculate this?
Old Jul 2, 2011 | 05:17 PM
08UnlimitedSahara810's Avatar
Of you have a navi, turn it on and compare the two.
Old Jul 2, 2011 | 05:29 PM
archijeff's Avatar
When I changed to 35's I seen about a 10% offset (speedo said 60 and I was actually 65-66).. When I went to 37's this jumped to almost 20%
Old Jul 2, 2011 | 06:17 PM
JK Rocker's Avatar
I think the faster you drive, the further off it is, so you can't really say the difference is a solid number, like 5 mph. If you have a gps of any kind, it should tell you how fast you are truly driving.
Check out the AEV Procal. It will correct this, as well as some other options, and its a lot cheaper than a full blown programmer.
Old Jul 2, 2011 | 07:48 PM
Wandell's Avatar
Loved
I agree. The higher the speed, the more the speedometer is off.
Old Jul 2, 2011 | 09:11 PM
Thanks for the input. Im gonna have to wait a couple months on the programmer. Until then is there a fairly accurate way to figure the difference on the odometer and mpg?
Old Jul 2, 2011 | 10:38 PM
Quentin_T's Avatar
Yep. Get the circumference of your old tires and the new ones. Take your new tire circumference and divide by the old one. This should give you a value similar to 1.12 (example only) and from that your mph should be 12% faster than what it reads.
Old Jul 3, 2011 | 06:22 AM
Wgrin's Avatar
Well your mpg just take your miles divided by the # of gallons you fill up with?
