A Mind of It's Own
Whenever I drive my Jeep at highway speeds it tends to steer itself or randomly pull one way. It's almost as if someone was grabbing the steering wheel and pulling it. Typically its towards the passenger side.
My question is will new adjustable front lower control arms take care of this problem and if so is there a certain degree that the front pinion should be at or do I just do a "trial and error"?
Thanks
Thanks
Well I just installed new gears about 2 weeks ago and I made it a point to go through the entire Jeep and make sure everything is torqued down like it is supposed to be. When I did all of this I still found nothing obvious and after driving it since the work has been done it still has this pulling/wandering issue.
i think the c/a's will help you in relation to getting your castor back closer to spec. i have the
4" TF springs on mine and i set the front lowers close to 23 1/4" to get the castor just less than 5 degrees. it's trial and error to get it right with each individual jeep/ mods and not get vibes in the front d/s. but,,, i couldn't tell by your post if it drove fine before the gear install and suddenly afterwards, it started driving like that???
-4" Rough Country-35-12.50 Mickey Thompson MTZ-ProComp 7005 Wheels-AEV ProCal-5.13 Gears-J.E. Reel Shafts
If they were 'not' installed for whatever reason, then you should consider a set of adjustable arms.
If Cams were installed, and you choose to go to adjustables anyway, you'll need to get the holes that were cut out for the cams welded back up before you can install the new arms. (though you could leave the cams and install the adj arms also, but don't really know why anyone would choose to do that...)
You should also browse through the FAQ's at the top of this modified area. Here is one section in particular to look at:
Q: What is Caster? How much do I need?
A: Caster is the angle upon which your front axle sits at in order to help keep your Jeep driving straight. Positive caster, which is what you want, will cause your axle to sit in a way that your pinion shaft will be dipping ever so slightly towards the ground. Too little or even negative caster angle can cause your Jeep to wander and feel 'flighty' or 'darty' as I've heard some people call it. From the factory, your JK will have +4.2° of caster and if you lift it and install larger tires, you will need to increase this amount to help compensate for the modifications. At 3"-4" of lift, I have found that +6°~8° of caster will do wonders to help improve the handling of your Jeep JK Wrangler.
http://project-jk.com/jeep-jk-write-...-end-alignment
-note that the +6°~8° of caster mentioned above is from an angle finder you place under the axle C's. It may not directly relate to the measurements given on a professional alignment machine.
And here is a member write-up for that kit. Note steps 11-13.
http://project-jk.com/jeep-jk-write-...ation-write-up
Thanks
Thanks
The problem on a lifted JK is that too much caster will at some point cause the front axle to start binding slightly (excess front pinion angle). Most threads I've read recommend ~6 degrees positive. The adjustable LCAs should help if the problem is caused by a slipping cam bolt or the cam bolt can not generate enough caster angle.
I just bought a lift kit that comes with cam bolts and I also a got a set of LCAs so I can avoid using the cam bolts. Just for good measure.
