Mini death wobble!?! Please help.
Old Sep 28, 2011 | 06:49 AM
wayoflife's Avatar
JK-Forum Founder
Originally Posted by Jknockers
Here is a suggestion, go out and turn the "toe" adjustment on the tie rod out (lengthen the tie rod) one turn, and then go for a litle test drive and see what it does. I did this and my death wobble went away and everything is good to go. Worth a try anyway.
toe out is a good way to address death wobble temporarily like getting you home from the trail but, it's FAR from a fix to what was actually causing it in the first place and, i would not recommend doing this for a long term solution. in addition to causing bad tire wear, it will mask your real problem which is most likely a loose, worn out or failing suspension or steering component.
Old Sep 28, 2011 | 07:05 AM
Bonedoc's Avatar
I'm not trying to step on any toes here, but I had similar problem on mine after I installed a 4.5" liftand 37s. Turned out 1 tire needed to be rebalanced and moved another that had balanced out to the rear and the problem was gone. Just saying, might want to rotate your tires around a bit.
Old Sep 28, 2011 | 07:07 AM
wayoflife's Avatar
JK-Forum Founder
too true. in re-reading the title and post, there is no such thing as a "mini" death wobble. you either have it or you don't. anything else is most likely a bad shimmy and most of those are caused by a tire balance issue.
Old Sep 28, 2011 | 07:20 AM
Jknockers's Avatar
I agree 100% with all responses,,, this just goes to show how many little things can cause a "wobble" in the front end, not to mention, that it CAN be a combination of a number of things that cause a "wobble". Sometimes it takes a few tries, on some things, to narrow it down.
Old Sep 28, 2011 | 07:30 AM
GMANUnlimited's Avatar
I just installed the lift and the jeep is brand new. I have double and tripple checked all the bolts to ensure there is nothing loose or damaged. When I was installing the lift there was no part that looked damged or warn. If I toe it out instead of in 1/16'' that shouldn't cause any major tire wear problems should it?
Old Sep 28, 2011 | 07:40 AM
saravonshep's Avatar
If you replaced the trac bar also make sure you centered the steering wheel. That being off even a little bit will give you a shake at the least.
Old Sep 28, 2011 | 08:05 AM
bstpierre's Avatar
Originally Posted by TheDirtman
Why would a off centered steering wheel cause a wobble? Please explain this.
It confuses the computer and causes it to turn on traction control and related systems to try to correct the perceived handling issue. Computer thinks "He has the wheel turned but he is going straight, I need to fix this." The results of this can seem to be a wobble but not full death wobble.
Old Sep 28, 2011 | 09:22 AM
duneslider's Avatar
Your description of the problem doesn't give much indication. Do you have a wobble, shimmy, or vibration? You say you don't feel it in the steering wheel, if.that is the case I would question the tire balance and driveline issues. 4" lift might be too much lift for you driveline.
Old Sep 28, 2011 | 09:38 AM
Originally Posted by planman
If all the control arm and trackbar bolts were not loosened for a lift install, then wait until after the tires are back on the vehicle on the ground at the new ride height to retorque the bolts, the arm/bar bushings are twisted/bound/pre-loaded at the wrong ride height.
Control arm and trackbar bushings and bolt sleeves for non-flex-joint ends should be in a neutral position at the new ride height. A non-neutral position will results in premature bushing failure and shimmy/wobble handling characteristics.
I can't remember who here decided to test this principle. However, one forum member loosened his control arm and trackbar bolts, jacked up his jeep so the suspension was at full droop, torqued the bolts at that level, then let it down and went for a drive. It was kind of a jumpy, shimmy, flighty kind of feel according to his report.
Then, he went home, loosened all the arm/bar bolts, vigorously rocked his rig front to back and side to side to unbind the bushings. Then, he retorqued everything to spec at the correct ride height and went for a drive. He reported that the jeep felt entirely different with the bushings in a neutral position.
So, if the logic doesn't convince you, you can always test it yourself like that guy did.
If something else is going on, read posts 1 and 2 of the DW thread linked in my signature below.
That sounds like very sound logic to me. When I installed the lift I did not tighten anything until I lowered it back onto the ground, but it might be worth a try to loosed and retighten all the bolts on the lift so see if that will reset a bushing that was pinched or bound.
Thanks for all the help I would have never thought of many of these suggestions.
Old Sep 28, 2011 | 09:45 AM
A shimmy would probably be the best word for the Problem. There is not any movement inthe steering wheel when the Shimmy is accuring. I am going to get the tires checked as soon I have time to see if that my be the problem. I dont think it's the drive line because I took it out and drove it around and the problem was still there.
