3 Attachment(s)
I'm looking for a minimalist rear to match the front. Any suggestions on what would look good? Attachment 656839 Attachment 656840
Attachment 656841 |
2 Attachment(s)
I regret doing the JCR Dagger. I love the bumper, but still not good with cutting off the rear cross member. I wish I did the EVO set up. It just wasn't available then.......
(Post 4245704)
1 Attachment(s)
Olympic rear frame cover. VERY easy to install yourself, less weight than hollow plastic stock rear, and a small fraction of the cost of most
VKS also has the EVO style D ring and Cover plate and is a lot cheaper. just sayin.
Home - VKS FabricationVKS Fabrication |
Originally Posted by Jeepstin12
(Post 4245706)
http://i35.photobucket.com/albums/d1...y/GEDC0427.jpg |
Most bumpers I've seen with a smaller than stock footprint will require you either remove or trim the rear crossmember. I went with the Crawler Conceptz stubby bumper and love it. I completely removed the cross member but if you aren't satisfied with how securely it bolts in then you could just weld it on instead.
Originally Posted by catahoula
(Post 4245707)
Yup! X's 2! I'm running the EVO's and love 'em.
Originally Posted by srohda
(Post 4245771)
What kind of modifications are required to install the evo i.e. cutting/drilling. You actually don't need to do any cutting if you prefer not to, but it looks much cleaner if you cut about an inch off frame horns. I love the setup, I can post up pics later |
