Mirror mod and Locker bypass DONE!
I'm just throwing this out there... but the owner's manual states the Tru-Lok feature will only activate when the following conditions are met:
- Key in ignition, vehicle in 4L (low) range
- Vehicle speed should be 10mph (16km/h) or less.
It does make you wonder why Jeep would set the limitations on the axle lock function like that.
I know when I activate my front locker my steering pretty much goes away or is very limited... so how well is the steering if the front lockers are engaged at higher speeds (i.e. while in 4Hi)?
My only suggestion is to be really careful at the higher speed so as not to tear something apart due to the lockers being engaged.
