Modding a 2012
Old May 2, 2012 | 06:15 PM
Redman333's Avatar
Default Modding a 2012
Where are you guys getting power and grounds from on the 2012s. Also where are you going through the firewall at.
Old May 2, 2012 | 06:17 PM
wayoflife's Avatar
JK-Forum Founder
if you remove the side panel of your dash, you will see a foam filled hole that goes through the fire wall. you can use a coat hanger to clear the hole and run wires through it and right to the battery.
Old May 2, 2012 | 06:20 PM
Redman333's Avatar
Thank you, going to look right now.
Old May 2, 2012 | 07:18 PM
mattgt5's Avatar
That is exactly what i did
Old May 2, 2012 | 08:17 PM
powrsurg's Avatar
Wayoflife,
Is this the same panel used when adding light switches? If so, is it easy enough to remove? Had performed this on my Avalanche and cracked the plastic screw hole on the panel.
Old May 2, 2012 | 08:44 PM
Christarp's Avatar
Originally Posted by powrsurg
Wayoflife,
I believe he means right here:
on the left (the very left) you'll see the side panel taken off and a red wire going into the foam filled hole.
Also, you can ground stuff on the metal dash part beneath that same panel (there's a bolt directly above the foam filled hole, and I just stripped the wire and tied it around that bolt and re-tightened it)
Old May 2, 2012 | 08:54 PM
powrsurg's Avatar
Thanks for the pic. It looks like the panels come off pretty easy.
Old May 2, 2012 | 08:57 PM
Christarp's Avatar
Yep, it does! Just pull a bit. Only held in by little tabs.
Old May 3, 2012 | 07:05 AM
Redman333's Avatar
I think I found mine last night. I'll post up some pics tonight when I get home for you guys. I know it's always nice to have a visual reference with some of this stuff.
