Modified Brakes
Old Apr 17, 2009 | 01:47 PM
YNV's Avatar
YNV
Default Modified Brakes
After almost an accident involving a wet road and another skid car, I want better brakes!
Are there upgraded brake pads for Wrangler?
Should I replace brake rotors?
Any difference between front and rear?
Old Apr 17, 2009 | 01:51 PM
greenamphibious's Avatar
just throw a paki in front of it
but seriously there really isn't much of anything out there.
Old Apr 17, 2009 | 01:58 PM
tkob1060's Avatar
From: Hangin in the sunshine state....staging forum..
I dont think the jk brakes are bad, but EBC makes some replacement pads with different levels of stopping power
h ttp://www.ebcbrakes.com/auto-pads.html
Old Apr 17, 2009 | 04:13 PM
paramaniac's Avatar
Originally Posted by rob4607
I woould like a full set of cross drilled rotors.
from what i have read, the cross drilled and grooved rotors just collect mud and dirt if you take your rig offroad.
Old Apr 17, 2009 | 04:19 PM
ricrac12525's Avatar
Default Brakes
If I remember correctly the new military spec axles have larger brakes, you may be able to order the parts to do a swap on your axles
Old Apr 17, 2009 | 04:25 PM
tkob1060's Avatar
IF you really want better brakes and want to spend some money, Camp can install Baer brakes
Crocker Off Road Performance is the first in the country to install a complete Baer Brake System in the 2007 Jeep Wrangler/Unlimited. We use a six piston setup on the front and 2 piston setup on the rear. This brake system is the same setup on the cars you see each Sunday turning left, and is highly recommended with the Hemi SRT8 6.1 liter option. Another COP4X4 Original Design.
http://www.cop4x4.com/services.shtml
Old Apr 17, 2009 | 05:28 PM
White Widow's Avatar
use the brakes off of a wj
Old Apr 17, 2009 | 05:45 PM
ronjenx's Avatar
Serious question:
If the stock brakes are good enough to lock the wheels and cause the ABS to kick in, what benefit would bigger brakes be? If heating/fading is the issue, is it a factor anywhere but on a race track, where you are accelerating/braking constantly?
Old Apr 18, 2009 | 04:41 AM
JPop's Avatar
I can assure you they don't lock and kick in the ABS at anything over 25mph, leaving a better brake package to have much improved 60-0 distances. EBC is definitely the place to start, and that should be plenty of additional stopping power for most people.
Old Apr 18, 2009 | 04:52 AM
this reminds me, i've been meaning to ask about the stock brakes, do most people find them adequate? especially with lifted knobby tires, thats alot of rotational mass you've got to being to a stop, let alone it's a 2 ton vehicle to begin with before modding.
