Mods to run 40s
I would like to get feedbak on all of you experts out there. I am planning on installing 40" tires with about 5.5" lift on my JKX. Besides upgrading/reinforcing the axles and steering. What gears would work best? What trimming needs to be done? Any suggestions on tires? Any other feedback or recommendations?
Pictures of JKs on 40s are appreciated.
you want to do this with a dana 30?? hell, i don't even recommend it with a 44. really, you can forget about gussetting, trussing and sleeves because none of that's going to matter when you blow your front axle shafts even if you upgrade to chromo. also, a 5.13 pinion on a dana 30 is super tiny as it is and i wouldn't even trust it with a 37. even if you only hope to do light wheeling, you really want to upgrade to something like a prorock 44 up front. if you hope to wheel harder even if just in the mud, you really want to be looking at 60's. again, this is more for axle shaft strength and side of your r&p than anything. you can still drive with a bent housing and beefing it up should be an afterthought to shafts.
Ok. So No mudding, reinforced axle and upgraded shatfs and D44 in the front? D60 when affordable. Thank you for the feedback! Keep all the comments coming, it is very interesting and useful!
I certainly want to have time to wheel and not spend most of the time with a rental and my JK at the shop.
Great advice you all
honestly, i simply do not understand why everyone always looks to gussetting and sleeving and completely gloss over AXLE SHAFTS. gussets and sleeves are nice to have but far from being as important as shafts - they are after all what will break and will put an end to your day.
i wheel with super big and heavy 40" toyo mt's and with the 3.8L - seems to have worked fine for me
You and Planman run 40s and seem to have no issues, but run different axles. Shafts you think are a must first?
well, if trashing a factory dana 44 front and rear axle is no issues, then yeah, i haven't had any.
i can't speak for planman but, you have to also understand that more times than not, i'm on the trail at least twice a month and in the summer time, playing really hard maybe as much as twice a week. of course, when we go to moab, we're playing hard everyday for the entire week.
