Mopar accessories
I just got the new catalog. They have wheels made to accommodate wider tires with 4.6"of backspace and performance axles and front assembly dana 44 with tru-lok a cold air intake kit and cat-back exhaust system and ring and pinion gear sets. I wonder if they can void your warranty with that installed.
To put it short, yes this can effect your warranty. If you read the sticky at the top of Modified JK Tech about Mod's voiding warranty (good info to know, bad that it happened the way it did) in its entirety you will find during this guys discussions with Chrysler they state "any" modified Jeep should be flagged at a dealership. Therefore every time you needed warranty work it would be looked at closely to determine if the mod's played any part in the failure. As many here know there are plenty of guys that have heavily mod'ed Jeeps that have warranty work done with no problem at their dealership, but it is definitely a risk you run and any dealer has the power to put this flag on your Jeeps VIN.
