Mopar relocation brackets vs Rugged Ridge
Okay, we all know that the Rugged Ridge Mirror relocation brackets have this issue: the passenger side mirror will be partially blocked with full doors reinstalled. Blocked at 50%
I want to know if the Mopar model is different.
- The passenger side mirror is blocked? Yes or no?
- At high speed, any vibrations ?
Here you go: http://www.quadratec.com/products/13125_5000.htm
That Mopar kit is a more expensive re-packaged Rugged Ridge kit. Compare the two on Quadratec's site and you can see it better.
I have the Rugged Ridge kit and there's no vibration and it looks stock. As you wrote, the passenger side is blocked by over 50% with the door attached. But I adjusted the mirror housing as best I could during installation and the mirror after and now I'm comfortable with the visibility.
Maybe they changed the Mopar kit since I bought it a few years back, but back then it only provided a driver's side mirror. It's actually a TJ mirror (you don't need to pull your JK mirrors) ...
I'm talking about the Mopar relocation brackets
