MORE body lift problem NEED HELP PLEASE
Old Jan 9, 2009 | 12:49 PM
  #21
jvalason's Avatar
Originally Posted by Will35
Yes I am serious. I did do one side at a time. I guess some are shifted farther forward at the factory than others. I thought I said this a couple of times already but I guess you didn't understand that.
Easy there killer we are just trying to help each other out...
Old Jan 9, 2009 | 02:35 PM
  #22
Will35's Avatar
Sorry, I didn't mean to come across rude. I was answering that on my phone typing and didn't realize how it came out. Please accept my apologies.
Old Jan 9, 2009 | 02:41 PM
  #23
DuDz40VT's Avatar
holy god that is the scariest thing ive ever read about!
I could not get the right front mount under the passenger door to line up so I ended up jacking the frame up reallllllly high untill I could insert the bolt and start the thred and then the body self corrected itsefl as i tightened everything all down. I thought that was extreme but my story is no where near the level of what you just did!
Old Jan 9, 2009 | 03:13 PM
  #24
jvalason's Avatar
I did the back up slam on the brakes deal...lol it worked! Good find! I respond on my phone to you can't really proof read and things can come out the wrong way
Old Feb 2, 2009 | 09:52 AM
  #25
mike79's Avatar
i may have to give this a shot
Old Feb 27, 2009 | 03:16 PM
  #26
HarryHood1's Avatar
So let me get this straight if you before you tighten all your body mounts down go in reverse and slam on the the brakes and you wont have to trim the inner boot. I ask because i am installing a MORE BL right now
Old Feb 27, 2009 | 04:31 PM
  #27
PONCH's Avatar
No you still have to trim. You just want to make sure the body is slid all the way back so you can shift. Doing just one (trim or slide) helps a little on their own and perfect when done together. Sounds a little redneck but that's the best type of engineering.
Old Feb 27, 2009 | 05:35 PM
  #28
HarryHood1's Avatar
not sure if anything is different on a 2008 but i pulled the shifter knob with everything i had and it never moved at all. Thing i need to buy a new inner boot i chingered this this up pretty bad. Anyone know how much they run
Old Feb 27, 2009 | 05:44 PM
  #29
JonnyCub's Avatar
thats why you just need to save and get a suspension lift. im not saying im just saying
Old Feb 28, 2009 | 05:03 AM
  #30
PONCH's Avatar
That's a whole other topic right there. 2.5 +1" BL is the way to go when your on a budget. If you got the dough then spend it on a long or short arm kit. Buying a kit over 3" suspension and not being able to adjust anything (long or short arm) and your asking for trouble. Don't forget some of us would have to buy drive shafts too.
