More lift
If you're only wanting another inch, there's really not a problem going with a 1" spacer. Anymore than that, I'd get springs. Springs will always be better than just a spacer though. You could go with the TF 4" springs and a 1" spacer too
Well that did not take that much to talk me into it, Im going with the 4" springs and 2.5 spacer, will I need to make any modifications to my existing suspension components.??
You would have to do some serious, if even possible, flexing to have your front spacer fall out on a JK, not to mention it has a lip on it that requires force to be pulled past the stock bumpstop mount. Also, the rear Teraflex spacers are pushed into the body and don't sit freely, so if you flexed your rear, it is still held in by the body.
Body lift with spacers? Half your lift is going to be aesthetic. If your wanting to increase articulation I'd take off the body lift and sell it. Then put in 4'' TF springs and put spacers on top of that if you want them. If you just want height then your current set-up with spacers will do just fine.
