mounting gas / jerry can
Old Dec 2, 2012 | 10:12 AM
joshsolo's Avatar
Default mounting gas / jerry can
im looking for a good place to install jerry cans. the wife wants to start exploring death valley and i would like to not get stuck out there. i dont want to buy a new bumper just to stick some cans up there. nor do i want to over pay for those new center mounting cans. i dont know how much the door will hold. looked at a I RACK from smitybuilt but i already have a 33 on a steel wheel can the back door take that much? any ideas on a DIY or a cheaper way of mounting gas cans?
Old Dec 2, 2012 | 01:02 PM
JKOwens's Avatar
How about a hitch mounted trailer basket? Would limit you a little but it would work without being too expensive and no modification.
Old Dec 2, 2012 | 02:17 PM
TheTerminator's Avatar
That would work only if driving smooth roads. But after one cross ditch this basket will blow to pieces. And forget about doing any serious off roading. I wonder if it's OK to just put gas cans inside. Anyone doing that?
Old Dec 2, 2012 | 03:09 PM
Patman's Avatar
I wouldn't want to carry this in the jeep. If the gas tank(s) happened to start leaking, where would the gas go?
Old Dec 2, 2012 | 03:38 PM
familytime's Avatar
JK Forum Regional Rep
Rotopax makes some great set-ups for extra gas,water.There mounting brackets are universal
Old Dec 2, 2012 | 04:00 PM
8052949's Avatar
I'm on the same boat but decided against carrying any extra fuel. It's just cheaper to spend a buck more a gallon and refuel in Panamint Springs or Furnace Creek.
Old Dec 2, 2012 | 05:21 PM
Why would it leak, given you use good, quality cans?
Old Dec 2, 2012 | 05:31 PM
4W-Jive's Avatar
This was the cheapest solution I found. Rotopax on a bracket that goes through your center cap and bolts to the spare lugs.
Old Dec 2, 2012 | 05:40 PM
Septu's Avatar
I would only do so if I'm leaving a window open for ventilation. Otherwise, it needs to be outside. Fumes get pretty bad. I was almost at the point a few years ago of pouring out close to 5 gallons due to the fumes. However a co-worker came by and I tossed it in the back of his truck. I had a 8 hour drive ahead of me and wasn't willing to spend 2+ hours with the fumes before using enough gas so I could use the jerry can.
Something I'm wondering about is a Teraflex tire carrier then have a buddy fab up something that allows me to carry a can on either side of the spare. Before I'd never consider it due to the weight... but with the TF carrier, the weight is off the door and on to the tub.
Old Dec 2, 2012 | 09:16 PM
joshsolo's Avatar
Originally Posted by 4W-Jive
Attachment 394455
ive seen these but there not cheap. you can find a jerry can for $35 at 5 gallon and up those start at $60ish at 3 gallon and still hanging from the door. so whats a 33 on steel with 3-6 gallons put on that back door. thats what im wondering will that door take the stress?
