Mpg
I have been keeping track of highway fuel mileage at different stages of my JK build up, and here is what I have found:
all stock, suspension, 255.75R-17 tires with 4.10 gears: 18 mpg
2.5" suspension, 35x12.50R-17 Goodyear MTR tires with 4.10 gears: 12 mpg
2.5" suspension, 35x12.50R-17 Goodyear MTR tires with 5.38 gears: 15.5 mpg
2.5" suspension, 35x12.50R-17 Dick Cepek Fun Country tires with 5.38 gears: 16.5 to 16.9 mpg
So, it apears you get much better gas mileage if you gear your Jeep lower to compensate for the bigger tires, because you will be able to keep your auto trans in high gear more of the time on the highway.
You will also get much better gas mileage by choosing an AT tire instead of a MT tire.
I have also been keeping track of my mileage as I have gone through different stages in my build. I have a 2008 Rubicon 6 speed.
All stock I was getting 15.5 mpg
With a K&N drop in filter I got 16.6 mpg
With a 3.25 lift and 37x13.50 Toyo MTs I got 14.98 when I corrected my mileage to account for the larger tires
After adding the Superchips Flashpaq I saw the following
15.36* with the 87 tune
15.07 with the mileage tune
I just switched to the 91 tune and am running 93 octane gas. I got 15.94 mpg at my last fill up. Right now it looks like I will be getting between 16.5 and 17 on the current tank of gas.
With the manual and 4.10 gearing, I will say that my gas mileage on the highway at 70-75 is as good as if not better now than it was stock. Stock in 6th I would be running 2700-2800 rpms and was getting horrible highway mileage. Somewhere around 15.6. I got the same highway gas mileage with my 37s before the Superchips flash as I did stock.
I have found that the sweet spot for mileage on these Jeeps seem to be around the 1700-2000 rpm range.
ETA * The gas mileage with the 87 tune is a little bit high. I was still dialing in the tire size in the flashpaq. I probably was much closer to 15 mpg.
hes what i got
2010 JK 4 door X
3.21 gears
stock X rubber
Bestop trektop
2.5 BB liift
Daystar hood "wranglers"
6 speed manual
my computers average is .. drumroll.... 21mpg!
it went up 1.5 when i added the trektop
i know guys that say teh automatic will eat gas mileage like its nothing... the 6 speed seems to help big time on gas milage - that and a light foot.
2010 JK 4 door X
3.21 gears
stock X rubber
Bestop trektop
2.5 BB liift
6 speed manual
hes what i got
2010 JK 4 door X
3.21 gears
stock X rubber
Bestop trektop
2.5 BB liift
6 speed manual
2010 JK 4 door X
3.21 gears
stock X rubber
Bestop trektop
2.5 BB liift
6 speed manual
Sahara unlimited with auto 3.73 gears 3.5 lift, K&N air intake gibson exhaust and hypertech programer on 87 octain and speedo recalibrated.
hand calculated driving easy combined city and freeway 17.5 it is best at 70 in OD any slower and it will lug, anything under 65 and I need to turn off the OD or It will backshift on inclines or head winds, driving with out thinking of fuil economy and I loose about 2mpg
The dash is within .5 mile per gallon accurate, I can get 19 to 21 on a freeway trip if there is no wind or inclines, If I pull a utility trailer with 4 dirt bikes I would be lucky to get 14mpg
