mudflaps install????????
is the factory mud flap install as easy as it looks... just hold them up and ram screws through the plastic. thats it.... am i correct... thanks all.
The install is very easy. It is even easier if you remove the wheels or have an angle drill. You need to use plastic "rivets" rather than screws to hold them on.
There are super easy to install. They come with all the necessary hardware. You'll probably want a drill motor and some bits, I forget the size but the instructions tell you what size to use. I just cramped my front wheels one way to do one side and then the other way to do the other side. Should take you a half hour or so. No big job.
