My 5.13:1 gear review.
Yeah, I got the AEV pro-cal with the lift so I recalibrated for tire size and for gear ratio before I drove a foot with the new lift/tires. I don't have a GPS so I am using the old-school "how many miles did I drive divided by how many gallons did I just put in the tank" method of calculating. I realize the odometer number I'm using 'could' be off, but since I recalibrated I'm assuming it's not.
A big part of this is where you are and the terrain you drive over. Chicago is very flat, the highways outside of when the suns down will rarely let you travel the speed limit and during peak traffic you use the brake pedal a lot more than the throttle. Not really much of an opportunity for the gear hunting that many others encounter unless you get outside the city.
Too many variables to get any kind of accuracy when comparing mpg.
As an example, on a recent 60+ mile freeway trip, I got 21.1 mpg
4door, auto, 35's, 5.38's, bumper/winch and a decent amount of added weight, Colorado altitude with lots of hills.
That is the kind of mpg you might hear about from a bone stock Manual. At sea level. On flat roads. With a tailwind.
Account for as many of the variables as you can before you compare...
