My build for the summer
I would be more concerned about running an incomplete 6" lift on the road then off. Speed kills. Poor geometry and improper steering at 65 mph is just dangerous. I would make sure no one else ever takes it for a drive. But it is your rig and you can do what you want with it. Personally I would not want to take that rig off road with that set up either. Have fun with the build and we will be here to answer the questions to the problems you are going to encounter with that lift after the fact.
Contrary to popular belief there is nothing wrong with RC lifts. I've been running my 4 in X-Series for a year now with plenty of offroad adventures with no issues whatsoever. I say to each his/her own and get what your pocket can afford. Even better piece it altogether and make a Frankenlift from different lifts....
. What matter the most is your satisfaction with what you have.
Honestly at the height id get all arms, driveshafts,ditch the pitman arm,flipped draglink,raised trackbar (axle side) not sure if the kit had both adjustable track bars, but thats what id want. even with all 8 arms im not sure how good of a pinion angle youll get on the front driveshaft. In the rear im not sure the coil correction wedges will be enough, id cut and rotate the stock spring perches. Id also make sure to have a grinder or sawzall to cut the body up to fit 37s. Also is the 6" a y link suspension set up? If so these really lack under any long travel shocks. Its Steering suffers, in that the links don’t allow rotation of the axle in relation to the frame as the suspension cycles up and down, which cause caster changes. This is all just a start, your steering and steering box may still hate you, just not as much. Id also look into another stock front sway bar to put in the rear so it dont rollover on a pothole. But as said, i bet you can get by with just lowers and driveshafts if you really want to...
But hey, it's your Jeep....
