My Procal just shut me down! HELP!!!!
Old Apr 21, 2013 | 05:13 PM
CajunTiger's Avatar
Default My Procal just shut me down! HELP!!!!
I just went try and set my throttle response, and now I have no accelerator at all....WTF happened? I then set the procal to Restore, and still nuttin....
Old Apr 21, 2013 | 05:37 PM
Rocky Clymer's Avatar
Make sure that between each change using a ProCal to unplug it and turn the engine to off for a few minutes. The ProCal is notorious for not making multiple changes while plugged in.
Old Apr 21, 2013 | 05:45 PM
kny21's Avatar
You have to do the song and dance quickly or it doesn't take.
And for anyone else the benefits claimed are a myth, don't bother trying it as you'll end up like the OP.
Old Apr 21, 2013 | 05:54 PM
jadmt's Avatar
JK-Forum Ambassador
It is funny how the inventor of the pro cal says the same thing but people still want to try lol. bummer for the op tho hope it all works out.
Old Apr 21, 2013 | 05:59 PM
CajunTiger's Avatar
I am doing it as quick as I can. Left it turned off for quite a few minutes and still nuttin....Guess its a wrecker to the dealership in the morning!
Old Apr 21, 2013 | 06:00 PM
CajunTiger's Avatar
What about the people on this forum that tell you to get a procal and all issues will be solved?....
Old Apr 21, 2013 | 06:25 PM
jadmt's Avatar
JK-Forum Ambassador
I think most only recommend for calibrating speedometer and shift points on auto and gear ration changes for different gearing as well as lane change and drl's. They also work for raising idle speed for winching but on AEV's forum there has been much bandwidth devoted to not messing with trying to change throttle response. They do great at what they are designed for and intended for. You might go to the aev forum and there might be some pointers on how to reset your system.
hopefully I won't get in trouble for this but if I do I figure it is a worthy cause. good luck.
American Expedition Vehicles - Product Forums - Powered by vBulletin
Old Apr 21, 2013 | 06:26 PM
CajunTiger's Avatar
I got it....I was using the highbeam flash on both to start and set the throttle setting, was supposed to use the flash to get it started and then use the highbeam on and off to set it.....ghesssshhhhh.....that was STUUUUUUUPPPPPPPPPIIIIIIDDDDDDDDDDD!!!!!!:d oh:
Old Apr 21, 2013 | 06:28 PM
CajunTiger's Avatar
Thats exactly where I got my fix for it. Thanks for the info....and it did give me better throttle response! Got everything else set up like before.
