My rear springs look Jacked-Up, this cant be right
Old Jul 5, 2012 | 09:53 PM
BlueBennett's Avatar
Default My rear springs look Jacked-Up, this cant be right
I have a 2010 2dr, i put on a 3.25 lift ( got 4 out of it) and this is what my REAR springs look like. This cant be correct. I just installed Adjustable LCAs and they are set to stock length. Do i need to make them longer or shorter?
Old Jul 5, 2012 | 09:57 PM
wayoflife's Avatar
JK-Forum Founder
don't see a pic but, assuming they are bowed, that is totally normal for a 2-door with that much lift. it's not a real problem but, in order to fix it, you will need to install adjustable spring perches like the kind jks makes.
Old Jul 5, 2012 | 10:34 PM
Sorry, had a little trouble uploading picks
Name:	rear spring.jpg
Old Jul 5, 2012 | 10:37 PM
wayoflife's Avatar
JK-Forum Founder
yup, totally normal. you can straighten it out but you will need adjustable perches to do it.
Old Jul 6, 2012 | 12:52 AM
What about coil spring wedges? I found some at quadratec for $25
Old Jul 6, 2012 | 12:53 AM
Does is cause damage to leave them this way and drive it?
Old Jul 6, 2012 | 01:00 AM
rinkishJK's Avatar
Rk makes wedges which will help correct it.. The best way is with adjustable perches like wol said.
I have the jks ones on mine and my springs are nice and straight.
Try the wedges and go from there.
Old Jul 6, 2012 | 02:18 AM
keithvegas's Avatar
Well, other than WOL telling you twice that it is normal I will give you cred for actually getting down there and noticing.
Old Jul 6, 2012 | 02:26 AM
RedJK2's Avatar
I've found that the RK wedges only partially correct the bow, and I will be going with the adjustable perches in the near future. If I were you, I would do it the right way from the start.
Old Jul 6, 2012 | 02:35 AM
CJ7nvrstk's Avatar
Vet Army
Wouldn't lengthening his adjustable LCAs correct that?
