i hate you all for keeping this thread off topic... props to dirt for a damn good write up...
Originally Posted by Maertz
(Post 3912813)
Originally Posted by jadmt
(Post 3912903)
x2.........
Originally Posted by terrabit
(Post 3915368)
x10000
Originally Posted by Vampyon001
(Post 3915520)
That's over 9000!
Ok back on topic...right...now. Sent from my iPhone using Tapatalk |
quick question probably been covered.
I run stock 32in bf mt tires on 17in rims. After these tires wear I want to go with a 35. I don't plan on doing anything to crazy but would like a 2.5-3in lift. I also would like new bumpers. Would a coil kit- say the rancho 3in trail kit suffice, and come with everything needed? Then down the road add shocks? I don't want to get into drive shafts or anything to major. Flat fenders will be coming as well. Looking at the smitty built flats. |
I would suggest you read the write up again. I laid out what the suspension components are and what they do. If you understand what is written you would be able to answer your question.
Originally Posted by jdenney
(Post 3916828)
I run stock 32in bf mt tires on 17in rims. After these tires wear I want to go with a 35. I don't plan on doing anything to crazy but would like a 2.5-3in lift. I also would like new bumpers. Would a coil kit- say the rancho 3in trail kit suffice, and come with everything needed? Then down the road add shocks? I don't want to get into drive shafts or anything to major. Flat fenders will be coming as well. Looking at the smitty built flats. Good luck! |
Thanks. 2014
Yep you will want to address the exhaust up front. :)
There are a lot of options for it: Drive shaft Cross overpipe spacers.
(Post 3917008)
Thanks. 2014
