Originally Posted by glazier
(Post 4071181)
Is it possible to run 35's with a 2" lift with flat flares? I only wanna lift my jeep to accommodate 35" tires which I plan on putting on when I burn my stock tiresout. I will also be getting new wheels with the proper back spacing of 4.5. Since I'm looking at aftermarket bumpers / winch, I'm going to have to do something like a levelling kit or a lift with new coils to take extra weight. I only wanna lift it once. I don't know what coils will be coming on my new JKUR as of yet. Still waiting on my vin to pull up the build sheet.
Excellent write up
Ok; I'm running 33's on 17x9's with a 2 in zone coil spacer lift and bumpstops. Most threads suggest a 2.5 in lift for 35's or as you recommend 2 in and flats. If a 2.5 in lift allows for 35's with with stock fenders and heavy front and rear aftermarket bumpers and winches...wouldn't a 2 in lift be almost the same with stock bumpers and 35's. I only do trails and ditches nothing hardcore requiring a lot of flex. Thanks for your help.:)
Originally Posted by 2sexy4myshirt
(Post 4085274)
Fantastic thread, reading it the last two days and learned a lot and has definitely changed my approach as to what to do.
Can I ask advice and guidance on belly clearance and break over... Just got a JKUR and when I went out last weekend, my biggest problem repeatedly was belly clearance. If I go from 32" to 35" and add a 2 inch lift (whether coils or spacers), would that raise my belly 3.5" from where I stand now? If I choose to go with small coil lift, and if I find that I don't have enough belly clearance still, what would/could be potential options for me then... Would I need to swap for a larger coil lift or could I add spacers or something else then? Thanks to all those who put in the time and effort to educate novices like myself. |
You can always go bigger but I will guarantee you will always find a bigger rock to get hung up on no matter how high you go.
It never ends, does it. that's part of the beauty and attraction to the jeep...
thanks
Originally Posted by TheDirtman
(Post 4095514)
1 Attachment(s)
Attachment 609605
This is with 40's a custom suspension with 20" of belly clearance. I was going backwards and had a spotter I didn't know. Choosing proper lines and experience will go way farther then an extra 1" of lift. Build your rig for what you do the majority of the time, if you have a dd that sees a few trails a year why sacrifice the on road performance by using a high lift so you don't have to have driver skills off road. I will try most obstacles but I still know my limits. And you are right it never seems to end. |
Thanks for the tips and knowledge.
(Post 4095644)
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=609605"/> This is with 40's a custom suspension with 20" of belly clearance. I was going backwards and had a spotter I didn't know. Choosing proper lines and experience will go way farther then an extra 1" of lift. Build your rig for what you do the majority of the time, if you have a dd that sees a few trails a year why sacrifice the on road performance by using a high lift so you don't have to have driver skills off road. I will try most obstacles but I still know my limits. And you are right it never seems to end.
(Post 4095644)
I would say bigger tires make the jeep look better, not a lift. Tall jeeps with small tires just look dumb. Same thing with big wheels and small tires like a 20" wheel running 33's.
