Need advice
Hey guys I just installed a 4" lift and put 35" tires on my wrangler unlimited. I've never done it before and everything is working great except for my traction control light staying on. Anybody know what it is and what i need to do to fix it??
This is how you want to adjust it. There is a write up in project-JK that tells how but its pretty easy. I believe it's a 15mm wrench and a pipe wrench or good set of channel locks. Pull in straight and lossen the bolts and then twist the drag link until the steering wheel is prefectly center. Then retighten the bolts problem will be solved.
Again, appreciate it guys... It was my first install and I called a couple of lift shops and see if they knew anything about it and they acted like they had never done anything like this before and wanted me to bring it in, along w my left nut, so they could look at it...but I'll be back in town this weekend and will give it a whirl...(nice to know I can count on someone when in a bind) ::thumbs up::
Originally Posted by jkd3624
Just shut Ur traction controll off then no worries
