Need Advice!
Old Sep 13, 2008 | 08:11 AM
mudy 07 rubicon's Avatar
Default Need Advice!
i was going to go with a 4 inch lift and 35 inch mud grapplers and new driveshafts on my 2dr 07 rubicon but I dont want to replace the driveshafts right now. Would I have to replace them if I went with a teraflex budget boost?
Old Sep 13, 2008 | 08:14 AM
Geeper4x4's Avatar
No, you would not need to replace driveshafts with the 2.5 bb even on the 2door. With the BB and a 1" body lift you could run 35's without anything else needed. The body lift gives room for the tires without raising your center of gravity much and that's a good thing with steep angles off-road. The body lift also doesn't effect driveline angles that will damage driveshafts. This saves you a lot of money for all the other mods you want to do!
wayoflife's Avatar
JK-Forum Founder
honestly, 4" is a lot of lift for just 35's. you should be able to clear them with a 3" lift. but, having said that, no, you would not need new driveshafts with just a BB.
Old Sep 13, 2008 | 11:16 AM
nocompromiseoffroad's Avatar
Default driveshafts
i know that X No Compromise Offroad X has some je reel drive shafts he is wanting to get rid of if that helps you>
Old Sep 13, 2008 | 11:48 AM
08UnlimitedSahara810's Avatar
I have the TF BB and have had no issues whatsoever. I am very pleased with it. I am running 34's but a friend is running 35's with no issue on his. The ride is excellent and it is very capable. The terflex rep on this forum is excellent and will answer all of your questions if you ask him. The best customer service I have seen in a long time.
Old Sep 13, 2008 | 02:02 PM
Default Thanks!
I think I am just going to go with the 2.5 TF BB and a 1 inch body lift. What body lift would you guys recommend?
Old Sep 13, 2008 | 02:49 PM
Geeper4x4's Avatar
How about one of our sponsors here at JK-Forum?
http://www.performanceaccessories.com/
Old Sep 13, 2008 | 02:55 PM
Ryno's Avatar
That's a good plan. It will save you money and probably give you more room for flex because you're moving the fenders up and out of the way.
To my knowledge, M.O.R.E., Performance Accessories, Daystar, and maybe a few other companies all produce virtually identical 1" body lifts. The main difference is what the pucks are made out of (aluminum, polyurethane, etc.).
Northridge4x4 has a special right now on Performance Accessories' 1" Body Lift. 105 bucks.
Old Sep 13, 2008 | 03:22 PM
2drREDROCK's Avatar
I really enjoy my 3" Fabtech lift everything you need,without having to change your driveshafts.
Worth the money I love it and clears 35" tires
http://www.quadratec.com/products/16119_050.htm
Old Sep 13, 2008 | 03:37 PM
Ryno's Avatar
If it is a true 3" lift, let us know when your front driveshaft boot rips and throws grease everywhere.
