Need advice for next upgrade
Old Aug 29, 2010 | 07:20 AM
u-joint's Avatar
Default Need advice for next upgrade
Up until now I've known what upgrades were most important to me and therefore what order I would tackle them. Now I'm at the point where I have a list of upgrades, but I am unsure what order I need to handle them in.
I am considering the following:
  • EVO Gussets
  • Rear tire carrier (possibly OR-Fab, or maybe RR's XHD bumper w/ tire carrier)
  • Oil pan skid plate
In my mind all these things are equally as important (did I mention that my spare 35 is on the factory carrier), but I am unsure of their order of importance. Due to a rather busy schedule I only make it off-road a couple of times a year, but when I do it's usually a combination of rocks and trails.
What order would you handle these upgrades in?
Old Aug 29, 2010 | 07:23 AM
oregon signs's Avatar
i think you have them in the correct order.
Old Aug 29, 2010 | 08:25 AM
Pluke the 2's Avatar
climbing underneath my JK yesterday after a run, i looked at the Oil Pan and there were some little scratches on it.
personally, i would get the oil pan skid first
Old Aug 29, 2010 | 07:25 PM
u-joint's Avatar
Yeah, I am a little torn between all of them.
I am starting to think the tire carrier will come last, as it is the most expensive as budget is a bit tight. Depending on if I can convince myself (or not) that I could pick up a welder and do the gussets myself I may do that one first. Otherwise it may be the oil pan skid first.
So many upgrades, so little cash
Old Aug 29, 2010 | 07:35 PM
mkjeep's Avatar
The factory C's are weak and prone to bending, I'd get those first.
Old Aug 30, 2010 | 05:12 AM
joneszj's Avatar
Your list is in the right order. Scratches on factory skid plates are supposed to be there. I've wheeled in the rocks a bunch and still run the factory skids until I can maybe afford some aftermarket ones. They arent a necessity, but I'd say the gussets are, and a tire carrier is close to being necessary unless you dont care about the tailgate.
Old Aug 30, 2010 | 05:30 AM
07JKRUBI's Avatar
x2. You think the budget is tight to get a rear bumper, bend the front C's and try to budget a new front axle or the repair costs. Jusy my
Old Aug 30, 2010 | 03:46 PM
u-joint's Avatar
Thanks guys.
This conversation definitely is reassuring, as it was very similar to the same arguments I had with myself over which direction to go.
I will be going with the gussets. In fact, the more I think about it the more I am really considering purchasing a welder and re-learning to weld. Obviously not on my Jeep at first , but eventually so that I could do my own gussets.
