Need anything else?
I ordered a Pro-comp 4 inch lift with the following:
Pro Comp JK Wrangler 4" Lift Kit Key Features
Provides additional tire clearance and ground clearance
installs quickly and easily
Includes 4 shocks
Rear track bar bracket with an eccentric adjuster allows perfect centering of the rear axle
Includes trac bar
Billet aluminum rear bump stop extensions
Extended sway bar links
Brake line extensions
Is there anything additional I should get like steering stabilizer, etc? Thanks
Includes 4 shocks
Includes trac bar
New driveshafts front and rear. I got mine from JE Reel and they work great. The stock driveshafts won't survive at those angles for long. I highly recommend a drop pitman arm for your steering angles if its not included also.
