Need anything else?
I just put a TeraFlex Leveling kit and coils from a 2010 Unlimited (....17/front-....58/rear #'s) and it definitely lifted it more than the 2" in front and 1" back.Unfortunately I did not take before/after measurements so I am not exact on how much. Alignment seems fine,all I had to do was center the steering wheel slightly. Is there anything else I should have done? There is no need for adj trackbar/low control arms is there? Front end does seem a little loose hitting bumps at highway speeds. Is this because of the lift?
If you got more than 2" of lift, you probably altered your caster a little and it may have moved your axles slightly off center as well. This will make your handling feel flighty or loose. Those problems are corrected with adjustable track bars and control arms.
I was wondering this also? I just installed an rc 2 1/2 lift and it said to adjust the steering i think. but my steering wheel is straight and everything seems to ride like stock, once you said something about the steering feeling loose i kinda started wondering if mine felt looser than before. maybe its just in my head?
A 2.5" lift will shift the rear axle approx 1/4" In my oppinion he would be wasting his money to get a adjustable Trackbars and Control arms to adjust a menial amount, if it would adjust at all.
I have 3.5" of lift in the front and 3" in the back and just used a trackbar relocation bracket.. and it's solid.. never get an ESP light, Steering is Centered and Alignment is true..
Any time you change the (CoM) & (CoG) of a vehicle is going to feel different.. I just think its extreme to consider all the extra equipment for a leveling kit & springs, unless he gained more than 3".. Sorry, I may be way off..
