Need a BL Doctor ... quick :(
Old Mar 15, 2008 | 02:34 PM
tricked919's Avatar
Default Need a BL Doctor ... quick :(
I am putting a 1" BL on my 2-dr today and I can't get the body to lift off the frame. I have all the dirvers side bolts loose and the passenger side bolts are OFF. I have all of them accounted for - each side has a front core, (2) at the rockers, rear cross member over shock, and rear bumper. (8) pucks all together PLUS the front cores. I'm jacking the pass side up on the body seam and its still taking the frame with it. I've even tried jacking it up at points up front and in the back to see if I could get individual mounts to separate ...and nada.
I've done much more complicated BL's before and never had this problem - WTF?
Old Mar 15, 2008 | 02:44 PM
Piginajeep's Avatar
not sure, are any wires of brake lines holding it down?
Old Mar 15, 2008 | 03:05 PM
tricked919's Avatar
I've gone over the undercariage like a hawk and I see nothing obvious - especially nothing that would hold it as tight as it is - I mean its like the bolts are still on. I don't get it.
Old Mar 15, 2008 | 03:07 PM
Piginajeep's Avatar
I'm throwing out Idea's. What about the grill?
Old Mar 16, 2008 | 08:27 AM
mkjeep's Avatar
Don't jack on the body seam, jack between the body mounts underneath, use some short 4x4's on top of a foor jack to dipurse the weight. Only thing I can think of thay may be causing it.
Old Mar 16, 2008 | 09:30 AM
easttnruby's Avatar
For sure use the 2x4 to disperse the weight but if you have two jacks, maybe(add disclaimer here) try lifting it from both sides at the same time. Good luck!
Old Mar 16, 2008 | 09:34 AM
zeeksta's Avatar
is there two under the rear seat above the rear axle?
like a tj?
Old Mar 16, 2008 | 09:35 AM
zeeksta's Avatar
8 plus the nose doesnt sound right.
Old Mar 16, 2008 | 08:39 PM
brianb1222's Avatar
There Are 2 In Rear By The Bumper 2 Over Axle And 2 On Each Side Plus The Two On The Front. I Just Did Mine And You Have To Jack It High Before It Makes The Gap. Make Sure You Really Loosen The Other Side Not Just A Little Bit Or It Will Stay Together. Hope This Helps
Old Mar 18, 2008 | 06:47 PM
broom's Avatar
I used a high lift jack on my Rubicon rocker guards. Worked great.
