Need a dana 40
Old Nov 17, 2012 | 08:14 AM
Dwight_Pollard706's Avatar
Default Need a dana 40
I need a Dana 40. I broke the 30 on my Sahara last night. Anyone know where to buy one?
Old Nov 17, 2012 | 08:33 AM
dahreno's Avatar
Default axle
No such thing as a Dana 40 . Quit saying that , people think you dont know anything .It is a Dana 44 . How did you break your axle , and where did it break , and are you sure it is broken. Dana 44s are pretty expensive , and if you can fix your old axle , depending on how you wheel , and tire size , it might be the way to go. Other than that , if you wheel like I do , you may want to look into a Dynatrac 44 , much stronger than a stock Dana 44 . You don't want to spend thousands of dollars on a stock axle and break it to , just go Dynatrac and don't have any worries.
Old Nov 17, 2012 | 09:29 AM
JeepersLife's Avatar
x2 but you could try calling around to junkyards to see if they have any D44's.
Old Nov 17, 2012 | 09:31 AM
suicideking's Avatar
Check the classifieds and craigslist in your area. Some of the more hardcore wheelers buy PR44's and sell their D44's. Also wouldn't hurt to check with mod shops in your area. They may have one taken off from someone that upgraded.
I bought a D44 that was nearly new for $1500. You can get a better price on an older one. Keep in mind if buying an older one though that the factory lockers can wear out.
To buy a D44 brand new, they run $3000.
If you just want to fix it cheap, you can usually find a D30 cheap. I sold mine for $400, less than a year old with a PSC diff cover.
Old Nov 17, 2012 | 02:43 PM
[QUOTE="JeepersLife"]
Yes I realize they are 44. Yes it's definitely broken. Its my axle shaft not the assembly.Right near where the u-joint connects to the axle. On the short side for the front. I mean yea I can get a replacement for pretty cheap, and it's no big deal to change.. I'm running 35x12.50r20. What do you think. I wasn't even doing anything that demanding that would have caused it to break. What do ya think?
Old Nov 17, 2012 | 02:44 PM
Wow. My thread is dumb. That's what I said. Not jeepers life
Old Nov 17, 2012 | 02:46 PM
Here it is
Old Nov 17, 2012 | 02:58 PM
jaker t5's Avatar
Just get a used one or buy some better shafts
Crap happens sometimes for no reason
Old Nov 17, 2012 | 08:59 PM
CerOf's Avatar
Psst....there is a Dana 40. He did mean to say 44 though.
It is a 40,000lbs tandem drive axle. Probably a bit overkill. Heh.
Old Nov 18, 2012 | 05:02 AM
mpkelley20's Avatar
If you just broke an axle shaft, you can easily get replacements. Same if its just a u-joint. With 35's, just get a nice set of chromoly shafts. Ten Factory, Alloy USA or G2 will run you about $500 a set and will be much stronger than stock. No need to replace everything. However, if you have about $6K burning a hole in your pocket, a Dynatrac Pro Rock 44 fully loaded with ARB locker would be a nice addition!
Edit*** And yes, running 35's on a dana 30 and having a shaft or u joint break is very common. I see it all the time when wheeling with my club. Most times it's a u-joint so guys carry spares and have gotten down to swapping them out rather quickly.
