Need a front driveshaft
Old Feb 18, 2010 | 02:08 PM
jkman77's Avatar
Default Need a front driveshaft
Grease is leaking out of cv boot on transfer case end of ds. Going to order a new one just wondering which one to go with and if you change flange one axel end do you need to be concerned about pionon pre load. And is it ok to just replace front? Back one is fine for now. 08 2dr x 2 ome hd coils
Old Feb 18, 2010 | 03:19 PM
spinlock's Avatar
Replacing just one DS is fine.
There are several great brands J.E.Reel, Woods, Coast, TF and others. It just depends on on your preference for price ~$300-$600 and reputation.
Old Feb 18, 2010 | 03:22 PM
Jbroom's Avatar
I assume you have an automatic. I replaced mine after the first serious wheeling trip. I bought a Tom Wood shaft and had no issues in installing it. Haven't replaced rear shaft and have no problems yet. Hav a 2 dr with TF 3 inch lift. Very common problem. The stock shaft hits the transmission case when flexed and tears the boot.
Old Feb 18, 2010 | 03:54 PM
jkman77's Avatar
6 spd. With 23000 on it after lift. With alot of moderate wheelin. Also has been a dd since son is using my car.
Old Feb 20, 2010 | 11:57 AM
jkman77's Avatar
Default Terraflex
Wanted to know if the terraflex front driveshaft will work with my lift . Do i have to measure and order a certain length?
Old Feb 20, 2010 | 02:52 PM
jkman77's Avatar
2 ome hd coils. Got just over 3" out of it. Adjustible lower ca up front and uppers in the back
