Need help
Old Dec 20, 2009 | 04:04 PM
willypapooh's Avatar
Default Need help
I changed out my rear brake lines to add longer ones. Well now my brake light is on and wont cut off. When i put the jeep in gear it goes forward and reverse coasting but it does feel like one of the brakes is still on. what do i need to do thanks
Old Dec 20, 2009 | 04:12 PM
nwjk's Avatar
Release the parking brake!
Old Dec 20, 2009 | 04:13 PM
lol i knew someone was going to say that. yea its not the parking brake
Old Dec 20, 2009 | 04:16 PM
twistedthrottle's Avatar
You may need to bleed the lines better.
all 4 gravity drain may help.
Old Dec 20, 2009 | 04:22 PM
nwjk's Avatar
Sorry, couldn't help my self. I would start with the simple stuff. Is the master full of clean fluid? Is there a leak? Did you get all the air out of the lines? Do the wheels spin freely? Did you leave a line clamp on? Is the pedal firm?
Old Dec 20, 2009 | 04:36 PM
the master is full and i havent found a leak, i have bleed it like at least 10 times. no line clamps. oh and the pedal is not frim but still brakes. i dont understand what would keep the brake tight?
Old Dec 20, 2009 | 05:25 PM
just took off the rear left wheel and the brake is tight against the disc. anyone know how i can release it?
Old Dec 20, 2009 | 05:49 PM
aldaman's Avatar
Try relieving the pressure by unscrewing the bleeding screw, then gently pry the brake pads (being careful not to damage anything) until the caliper compresses. You will have to bleed the brakes again...The rule of thumb is to bleed the caliper farthest from the master cylinder...
Old Dec 20, 2009 | 05:58 PM
just lifted up on the ass end and spun the tires and the spin with no resitance . but when i look at the pads they look like there firm against the disc. so my question for this is how far are the pads suppoesed to be from the disc?
Old Dec 20, 2009 | 05:59 PM
thanks i am going to try and gently pry them open right not.
