Need help!!!!
Old Oct 23, 2013 | 07:15 PM
zero_traction69's Avatar
Default Need help!!!!
Just bough a set of rear axle shafts for my rubi, 32 spline ten factor. I know the 32in one goes to the drive and the 31 goes passenger. I can't get the drive side read axle shaft to go in! Anyone run into this problem idk what to do? Or am I doing something wrong
Old Oct 23, 2013 | 07:38 PM
Anyone???????
Old Oct 24, 2013 | 04:51 AM
Bonedoc's Avatar
I'd call the manufacturer. Call tech support
Old Oct 24, 2013 | 05:15 AM
planman's Avatar
Forum Tech Advisor
Did you remove the bearing race from the stock shaft?
Old Oct 24, 2013 | 08:47 AM
planman's Avatar
Forum Tech Advisor
Or, is the race still in the housing?
Old Oct 24, 2013 | 08:51 AM
rays0852's Avatar
I have a non-rubicon and replaced my rears with Ten factory shafts and they were the same length. OP says his were different lengths.
Am I missing something?
Old Oct 24, 2013 | 10:10 AM
JE8154's Avatar
Originally Posted by rays0852
I have a non-rubicon and replaced my rears with Ten factory shafts and they were the same length. OP says his were different lengths. Am I missing something?
different shafts chief
Old Oct 24, 2013 | 10:56 AM
nthinuf's Avatar
Rubicons have a different setup than non-rubicons. Their axle shafts are slightly thicker and have different lengths than the sahara's/x's/sports/whatever other models are out there.
Old Oct 26, 2013 | 11:09 AM
Figured it out, way of
Life's write up is wrong. That's the one I was going off and he said the passenger side was the short axle and the drive side was the long axle. Swapped them and it went in perfect! Feel so dumb =[
Old Oct 26, 2013 | 02:30 PM
Ryan0260's Avatar
What? He was wrong on something? Lol..
