Need Help
Old Oct 13, 2008 | 05:38 AM
Zebco99's Avatar
Default Need Help
Hi guys, sorry this may be the wrong spot to post this but technical question RE:driveshafts I have the Unlimited rubi with a toasted rear driveshaft ... question is will a unlimited X driveshaft w/d44 rear fit? I am kinda stuck here
and can't get home unless this works.
Zeb
the part #s are not the same but the diamensions are..?
Old Oct 13, 2008 | 08:21 AM
Frog Rubicon's Avatar
Not sure, but I don't think so becauce the X and Sahara have a different t-case
Old Oct 13, 2008 | 08:39 AM
Robar's Avatar
The transfer cases may be different but the output shaft is the same. The rear drive shafts should be the same and interchange with no problems.
Old Oct 13, 2008 | 09:30 PM
Zebco99's Avatar
Shafts are the same (thank God) they are identical and different part #'s
Just got home from Rausch thanks to all for the great help..
All the Best
Zeb/Rod
Old Oct 13, 2008 | 09:35 PM
hyatt147's Avatar
Thats good that they are the same. This kind of raises a question nor me though.
I wonder if I could use a 4 Door sharft on my 2 door to hold off on getting a longer shaft for a while.....I could just be dreaming for a quick fix
