Need Help
Old Jan 16, 2009 | 05:24 PM
BigTexRedneck's Avatar
Default Need Help
OK I know a ton of people have asked this so its my turn.
I need a lift kit, 4in for a 2 door but I would like to get the most complete kit i can buy. Any help?
Old Jan 16, 2009 | 05:35 PM
Pwermker's Avatar
Well, you probably need to answer some questions to get a better idea of what you want. You have to remember also, some answers will be personal preference.
How much do you want to spend? What will the JK be used mostly for, extreme rok crawling or your basic mud hole powerline outing? Are you going to install yourself? What size tires are you wanting to run?
I am installing a Rough Country 4" in the morning. I also purchased the new dual front stabilizer they just marketed. After alot of research on here, I decided not to use the cam bolts and bought Rustys adjustable lower front control arms.
Good luck with your decision, and search, search, search. There is a plethera of info on here.l
Old Jan 17, 2009 | 05:36 AM
I need a trail jeep, both rocks and mud and yes I do know it's hard to find a kit that will do well in both areas. The tire size will change because of the mods i'm planning on doing (like tube fenders)
Old Jan 17, 2009 | 05:54 AM
PONCH's Avatar
What size tires?
Old Jan 17, 2009 | 07:55 AM
ha ha well 37s to start with but i know i could get 39 underneath if i wanted to
Old Jan 17, 2009 | 07:59 AM
BBirish's Avatar
you probably are going to need new driveshafts and longer brake lines too if you are going to be taking it off road. also with that size tire a regear will be necessary if you want to keep your acceleration close to stock. But it will all be well worth it
Old Jan 17, 2009 | 08:49 AM
No actually that helped alot since some of the things on that list is already done or wating to be done
Old Jan 17, 2009 | 11:13 AM
BBirish's Avatar
let us know what you decide to go with
