Need help deciding
Old Aug 19, 2014 | 09:41 AM
Yuriy's Avatar
Default Need help deciding
Please help. I want to buy a lift kit. I narrowed it down to 2.
1. AEV 2.5" Dual Sport XT
2. TerraFlex 2.5" with shocks
I've read good and not so good about both. I know I don't want to go more than 2.5" lift. I do off-road once every other month. I got 4 door, will be getting 35" tires. It is my DD.
Which one is more complete kit for the money?
I don't want RK because with shocks it comes out a lot more money.
thanks.
Old Aug 19, 2014 | 09:45 AM
afalletta's Avatar
I've got the AEV on my 2 door and love it I'm putting 35"s on it this week and also bought the geometry brackets with the kit and love it, it rides better than stock and is awesome off road, it all depends on what kind of off roading you do
Old Aug 19, 2014 | 10:25 AM
Mark Doiron's Avatar
Originally Posted by afalletta
... it all depends on what kind of off roading you do
This. ^^^^.
And Teraflex makes a couple different 2.5" lifts, depending if you overland at heavy weights or not. If you do and you buy their cheaper kit, you may have trouble with rear end sag. I did and fixed it with OME HD rear springs (that was before TF announced their overland lift).
Old Aug 19, 2014 | 12:00 PM
Yuriy's Avatar
I'm not doing rock crawling! I normally go on easy/moderate trails, and sand dunes. I have aluminum bumpers to keep the weight off!!
what height should I except out of AEV lift??
Old Aug 19, 2014 | 12:29 PM
Invest2m4's Avatar
Originally Posted by Yuriy
I'm not doing rock crawling! I normally go on easy/moderate trails, and sand dunes. I have aluminum bumpers to keep the weight off!! what height should I except out of AEV lift??
AEV is designed for a good amount of weight. Hence the name American Expedition Vehicles.
If you're light, expect up to an inch more than advertised.
Old Aug 19, 2014 | 12:56 PM
Yuriy's Avatar
Originally Posted by Invest2m4
AEV is designed for a good amount of weight. Hence the name American Expedition Vehicles. If you're light, expect up to an inch more than advertised.
if my jeep will be sitting higher than 2.5", will I need additional parts (a lot of people say on this forum,3" and higher lift requires more add on-s )?
Old Aug 19, 2014 | 01:17 PM
nthinuf's Avatar
As you go taller, you are more likely to want to put more money into it, but it is a personal opinion, not a requirement. You can slap 5 or 6 inch coils on and do nothing about the issues it causes if you choose. Completely up to you.
Spend a few minutes learning what issues taller lifts might cause, and what the various components actually do, so you can make a more informed decision.
Old Aug 19, 2014 | 01:54 PM
afalletta's Avatar
Originally Posted by nthinuf
As you go taller, you are more likely to want to put more money into it, but it is a personal opinion, not a requirement. You can slap 5 or 6 inch coils on and do nothing about the issues it causes if you choose. Completely up to you. Spend a few minutes learning what issues taller lifts might cause, and what the various components actually do, so you can make a more informed decision.
What issues could I come across after installing what the kit comes with?
Old Aug 19, 2014 | 02:01 PM
afalletta's Avatar
I have the geometry brackets and also installed a bilstein steering stabilizer when I I stalled the kit
Old Aug 19, 2014 | 02:04 PM
FireRescue707's Avatar
The Rancho Trail kit is pretty complete also at a reasonable price.
