Need Help finding suspension???
Depends on the kit, since no 2 brands lift the same amount. TeraFlex 4" kits come with new front and rear brakelines. Now with the 2.5" kits, they come with rear drop brackets. The 2.5" coil kits will lift the front 3.1" and are great for 35's.
so if I'm looking for a 2.5-3.5 inch lift with out extending break lines and not took expensive what do you recommend?
does anyone have any info on the rough country kit and hot good or bad it is?
Jeep JK Wrangler Suspension Lift
bump
bump
Find some people with different lifts and do some test driving. Some lifts are better for off road some better for highway. AEV 3.5 is great for on and off road and will look great with 35s. Some 4x4 shops will let you drive there rigs to check stuff out.
Originally Posted by Cherryjk
Compare the RK and TF. Both are great kits just depends on what you want in the kit. Call northridge4x4 they can help you and the have a sell on RK right now
Seriously man not to sound harsh or anything but did you even think to look at using the search on this forum?
This is by far the most talked about topic on the forum most likely. Not only is there write up and opinions on most every major lift out there already. There is excellent sponsor support that you can contact directly about specific questions regarding the products. If you get real fancy you can even find full install walkthroughs for most as well.
Haha next week I bet you are going to ask what is the best 35inch tire for a daily driver with some off road ability that is not too expensive but is not cheap. Priobably also toss in where can I get a deal on 16 inch black wheels and what backspacing should I use.
Either way good luck on your project.
