need help with jeep problem
Old Apr 6, 2012 | 08:05 PM
OFP4LIFE's Avatar
Default need help with jeep problem
so i installed 4.88 gear in the rear and new rear axle shafts i took my front drive shaft off since i didnt finish the front so i can still drive. but my abs is engaging and not letting me drive. ill be finishing the gear tomorrow and i dont know why this is happening anyone run into this before????
Old Apr 6, 2012 | 08:35 PM
nvertflyer's Avatar
yes.when i did my arb 35 spline conversion i ran into the same problem.your abs tone ring is not in line with your sensor,the solution for you is most likely to press the tone ring outward twards the axleshaft flange....aprox 1\2 ingh from flange,this is what cured the same problem for me.im pretty sure this will cure your problem,hope this helps...
Old Apr 6, 2012 | 09:28 PM
OFP4LIFE's Avatar
ty
Old Apr 7, 2012 | 03:47 PM
OFP4LIFE's Avatar
so the problem was the spacing on the abs sensor. it needed 4 washers where the bold holds the sensor so that it lines up with the abs ring. im so mad at nitro axles nothing mentioned the fact that the abs ring is in a inner location from stock.
