Need Help- Leaking fluid
I just had my gears changed out and had the 500 mile check up. Everything looked good until today when I noticed that I have fluid coming out of the front drivers side drive shaft right next to the front wheel. Can anybody tell me what my problem might be?
Thanks:eek2: |
Sounds like the axle seal, it could be that it was overfilled or I've also heard synthetic fluids will sometimes leak as well.
Originally Posted by Hollywood218
(Post 518103)
Thanks:eek2: BUT if you still have the stock covers, check to make sure its not just coming out the axle breather tube which goes up to the top of the shock tower on the drivers side, it has a little white cap on it, see if the fluid is dripping down that. |
Thanks for the help. Either way it does not sound to serious.
not serious.................
